It is currently Sat Aug 09, 2025 12:16 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Tue Oct 24, 2017 1:12 pm
Wow, you guys are fancy. I just set the angle on an Incra miter gauge, cut slightly under size on the table saw then get the precise fit with a chisel. Only takes a few minutes. Since every guitar I make is slightly different it doesn't make sense to build a jig IMO.
PostPosted: Tue Oct 24, 2017 3:48 pm
kencierp wrote:
Here's an adjustable "X"notch jig that does not require power tools -- just a razor saw.
http://www.kennethmichaelguitars.com/Xb ... guide.html
Neat!!
PostPosted: Tue Oct 24, 2017 5:18 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
meddlingfool wrote:
I know my tablesaw sees a lot of use. Enough to buy one for each end of the shop...
Agreed and can occasionally double as another work/clamping surface. The best jig for me yet though is definitely the powered fret slotting jig with my table saw. What a time saver.
PostPosted: Tue Oct 24, 2017 6:19 pm
I hardly use my tablesaw for anything anymore. I got a Laguna SUV which handles straight cut operations. The tablesaw now has dados as a permanent feature, which is used for lapping the x's and cutting the t rod slot. All I need to do is adjust height depending on which job is going on...
Users browsing this forum: No registered users and 41 guests
